System Requirements
Microsoft Windows
The software and hardware prerequisites for installing LibreOffice on a Windows system are as follows:
Administrator rights are needed for the installation process. It is a recommended best practice to back up your system and data before you remove or install software.
For certain features of the software - but not most - Java is required. Java is notably required for Base.
Apple macOS
The software and hardware prerequisites for installing on a Apple macOS computer are as follows:
It is a recommended best practice to back-up your system and data before you remove or install software.
Notes:
GNU/Linux
As a general rule, you are recommended to install LibreOffice via the installation methods recommended by your particular Linux distribution (such as the Ubuntu Software Center, in the case of Ubuntu Linux). This is because it is usually the simplest way to obtain an installation that is optimally integrated into your system. Indeed, LibreOffice may well be already installed by default when you originally install your Linux operating system.
The community-supplied LibreOffice installers are provided for users having special needs, and for out-of-the-ordinary cases.
The software and hardware prerequisites for installing on Linux are as follows:
Android/Linux
See LibreOffice Viewer for Android.
Other Operating Systems
Community-provided builds of LibreOffice are available for other operating systems such as the BSDs. For more information, please see extended System Requirements on the TDF Wiki.
